dangerboy
I am trying to inspect and possibly replace the damper pads on my A612 Maytag dryer. I bought this washer a while go to put into service at my cabin and so far I have replaced the belts and the inlet water valve on it. I want to make sure the washer is good to go for a long time before I put it in service. I have tried loosening off the nuts on the eye bolts about as far as they will go without completely releasing the springs and then balancing the washer on a 4x4 but doing that only lets me see the very bottom of the damper pads which appear to be in reasonable condition but maybe worn down to the last couple millimeters of pad.
It seems to me the only way I'm going to be able to see the entire damper pads is if I remove the nuts on the eye bolts completely and release the springs. What I'm wondering is how difficult it's going to be to get the Springs back into the eye bolts if I release them. They seem like pretty stiff Springs and I am just here by myself.
Also, if I've got a couple millimeters of wear still left on the pads, should I bother trying to replace them at this point or are those pads likely good to last for quite a while longer given that this cabin only gets used in the summer and the washing machine doesn't see a whole lot of use during the entire year.
Thanks.
Thanks.
