tmadden
Hello, I have a Maytag A612 washer that has finally developed a problem, it sometimes won't agitate unless I move the agitator in the tub just a bit by hand, then it will agitate just fine. First time it happened it burnt the drive belt, so I thought it just needed new belts. Put on new Maytag belts, it was fine for a few cycles, then again it wouldn't start to agitate , until I "helped" it a little, then it was fine again. Doesn't make any ugly mechanical noises at all, when it works it sounds fine. No water or lube leaks above or below the orbital transmission. Current plan is to lay it down on it's back and remove the cover from the transmission and have a look inside. Got some form-a-gasket to reseal the cover, and will drain old lubricant and replace. What should I be looking for inside the transmission? Or elsewhere? I'm not a washer repairman but have a backround in industrial machine maintenance. Thanks for any tips!
