I'm enjoying my 710 but have questions.
Does the bleach dispenser just basically put liquid bleach at the bottom of the tub at the beginning of the wash or does it actually release it later into the load?
Is the pump belt driven? And how fast should the tub drain? I find that it seems to take the machine about 2 minutes to drain. It has a new hose, but you can hear water sloshing around for a little while longer than I thought it should. Does this mean that the pump could be clogged? I also notice a wet odor after use that never goes away.
Help would be appreciated!
Greg aka Luxflairguy
