Hi folks, this is my first post in this wonderful helpful forum so if you'll bear with me I'll give a little background before the main question.
My 1973 vintage A806 was causing concern because of a loud squeal at the end of the spin cycle, and running out-of-balance almost all the time, even with an empty basket. I could see the damper pads hanging out, so it seemed that replacing them could fix the balance problem, and I decided to get to them by removing the whole tub since I wanted to check the brake too because of the squealing.
The brake looked like it just needed to be cleaned and oiled. But taking it apart damaged the paper gasket so I cut a new one out of a file folder of the same thickness. It is glossy on one side but I don't think that will hurt anything.
So with the tub out, it made sense to also remove the pump and motor and clean the whole inside since there was a lot of rust in some areas. I am in the process of painting right now.
Now my main question is about the drain pump. Hoping to save this one, I have searched the forums but found no comments on the subject of repairing the pump. Are they not repairable?
The pump did NOT seem to be leaking. The only problem was that it was hard to turn. I took it apart, and it looked like it just needed cleaning and fresh lubrication.
The thing is, I don't see why it would not leak. Looks like the only thing keeping water from running out along the shaft is a plastic washer thing pressed up against a metal shoulder on the shaft, and maybe a little bubble of air that might be trapped there. Doesn't seem like much of a water seal. Also in the relief where the shoulder meets the shaft there was something that looked like thick old grease but I don't see how that would make a difference.
I'm wondering if I can put this pump together again, and if there is a trick to putting it back together so it won't leak. I would appreciate any comments, thanks.
