nuwash
So I started digging into the old beast today. I cleaned and greased the motor slides, freed up the pump (just had ice in it), and cleaned up the inlet valves. Iron Out removed all the junk. I soaked the lint filter in Spic and Span and it cleaned right up. I don't have a spare water hose so I can't test the valves yet. However, I did advance the timer to spin and fired it up. It spin just fine! I think because it's so cold here and it was kept in a garage perhaps the gear oil was just so cold it wouldn't move. It's in a climate controlled basement now.
As for the drainage question. The pipe opening I can put it in is a good six feet off the ground. Does the pump have enough power to push the water up that high? If not I was considering making a homemade 'lift station' with a sump pump and large bucket.
