best_intentions
Hi,
This is my first post but I have been to this forum many times in order to learn.
We have a Maytag top loading washer. It is a model A408. I love this machine as it is a solid workhorse and is really simple to diagnose and repair. The bearing is starting to squeak on the spin cycles so I want to replace this myself. My problem is that the agitator (teal color with no set screw) is definitely stuck on that shaft. I bought a replacement agitator in case this one gets damaged during removal. The replacement is the type with the set screw but otherwise identical. My question is simply this, can the set screw type be used as a direct replacement for the type I am dealing with now? If so I will feel free to get rough removing the old agitator. Thanks for any information you can provide.
John
John
