Maytag Atlantis water level
spinseed
Oct 4, 2009
I have a Maytag Atlantis TL washer. The highest water level on this machine does not reach the top row of holes in the tub and I always end up topping up with a bucket when washing a full load.
Is there anyway the pressure switch can be adjusted to increase the water level?
like any other machine. remove the back panel and turn the set screw on the pressure switch clock wise 1/4 turn, let machine fill and see where it comes to, you may have to do this several times, drain and completely refill, until you get to the level you want
BE SURE TO UNPLUG UNIT WHILE MAKING ADJUSTMENTS!!!!
