Maytag brake assembly not stopping tub
scrubflex
May 12, 2008
1,083
bronx, new york
What can cause a new brake assembly to not stop the tub at the end of the spin cycles?
Could too much oil jam up the brake assembly?
Although I have new spin bearings, Brake Rotor, and Radial Ball I still manually have to turn the tub to start it spinning.
Hi Harry, Is your washer not stoping at the end of spin or not starting to spin on its own ? or both ?
It may be that the lock key is not installed in the proper position on the bottom of the transmission shaft ?.
As many are finding out MT DC washers are one of the most difficult older machines to repair, this is why back in the day very few used washer shops ever bothered with them and kept rebuilding WP BD and GE FF machines instead.
John L.
<a style="font-family: 'Times New Roman'; font-size: medium; font-weight: 400;" name="start_89686.1142894"></a>
Stop lug adjustment play is set too tight. It's 1/4"- 3/8" using very light finger pressure.
Hey John L, Dan, it's both. When I first installed the brake, it stop the tub but, made a 'schrencing" sound when the tub stopped.
I added another teaspoon of oil to the brake thinking it may stop the noise...(maybe it was too much). Now the brake is not working at all.
I was under the impression that Maytag washers were easier because of simplicity in design and easy access to repair/replace all of the major components.
That's why I took on the challenge of the rebuild. Besides, when I replaced the brake assembly the first time, in 2010, there weren't any of these problems.
Dan, I'll retry and use 1/4" or 3/8". I followed the 'appliancerepairman videos' and used his suggested 1/2" space amount for the stop lug positioning.
It worked all these years, so I'm confused.
The transmission helical still look a little rusty after cleaning it...and dry
