Hi All. I recently took my DE806 (September 1969) apart, all the way down to removing the drum from its perch and oiled everything down with Zoom-Spout as many of you recommend. I finally got the unit back together today and everything works well except the dryer shuts off before the clothes are dry. We had to start the dryer 4 times before the clothes were fully dry. We never had an issue with this before, and we've owned the dryer for it's whole life, and so I'm hoping someone can enlighten me as to what I might have done inside the dryer to cause this issue. I'm not sure which part was the temperature/moisture component that dictates the length of the cycle - possibly I moved it or misaligned something? The one place I got stuck during reassembly was with the internal felt ring that goes between the drum and the mount. That's encompassed and held on by a thin metal ring with an electrical terminal on it. I was unclear how much of the felt goes underneath the metal ring, how much it should extend to touch the drum assembly, etc. I just made sure the felt extended to touch the drum assembly - I figured it was to catch coins or other foreign objects that would otherwise possibly fall into the maching and foul things up. Why it has an electrical terminal I couldn't tell you - possibly to dispel static? Any info you could pass on would be greatly appreciated.
