beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #2 Here's the top. Took everything out of the control console except the temp/dryness control switch, the switch plate activator, the bell and solenoid, and transformer. Later I'll take these out.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #3 Close - up of non removed parts.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #4 Over-head view.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #5 Front and top off. Light bulb removed. Wire labeling started.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #6 Close-up of tumbler.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #7 Where filter slips in and warped filter guard.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #8 Wires from console.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #9 Terminal block.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #10 Hole in top of inlet duct.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #11 Dirty exhaust duct.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #12 Found a comb and ATM card inside duct.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #13 Socket in good condition.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #14 Lens in place.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #15 Filter in good condition.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #16 Parts and equipment for work.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #17 Dirty outlet duct and wheel.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #18 Top/Cool-down thermostat. Bottom right/Low-cycling thermostat. Bottom left/Regular cycling thermostat.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #19 Starting to remove wiring.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #20 Heat chamber and shield before removal.
