beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #1 Here's the top. Took everything out of the control console except the temp/dryness control switch, the switch plate activator, the bell and solenoid, and transformer. Later I'll take these out.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #2 Close - up of non removed parts.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #3 Over-head view.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #4 Front and top off. Light bulb removed. Wire labeling started.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #5 Close-up of tumbler.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #6 Where filter slips in and warped filter guard.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #7 Wires from console.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #8 Terminal block.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #9 Hole in top of inlet duct.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #10 Dirty exhaust duct.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #11 Found a comb and ATM card inside duct.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #12 Socket in good condition.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #13 Lens in place.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #14 Filter in good condition.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #15 Parts and equipment for work.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #16 Dirty outlet duct and wheel.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #17 Top/Cool-down thermostat. Bottom right/Low-cycling thermostat. Bottom left/Regular cycling thermostat.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #18 Starting to remove wiring.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #19 Heat chamber and shield before removal.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #20 Dryer front before painting.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #21 Dryer front has been replaced as evident from model number 408.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #22 Serial number indicates manufacture date as Aug. 1976, but I know that's not true.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #23 I'll go with motor serial number EG (April 1980).
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #24 Diagram I made.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #25 Schematic. I used spray adhesive to glue down the edges, then covered the label with packing tape for protection.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #26 Switch cleaned, soaked with silicone spray and blown out with compressed air.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #27 Back of switch.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #28 Parts collection in drawer gets bigger.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #29 Tumbler front.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #30 Worn out tumbler glides.
