Maytag designs
gelaundry4ever
Nov 18, 2014
4,108
Temple, Texas, USA
Hello everybody, I have become fond of the Maytag design washers as of recently. I have used a Maytag orbital drive on my dorm to wash a load of clothes. How does the drive system look on the commercial version? What made these older designs last so long?
What weight of oil did Maytag use in their transmissions? I am talking both the pitman and orbitals. Inquiring minds want to know. I never thought that I'd personally use the Maytag. I believe they had the sark fin on the commercial units. Please correct me.
I don't believe Maytag ever announced the thickness of their oil; It was sort of a guarded secret for whatever reason. The stuff used in pre 1975 transmissions was pretty darn thick. My guess would be somewhere in the neighborhood of 140 using gear oil rating specs (motor oil and gear oil do NOT share the same ratings). The newer oil used in later pitman transmissions and Orbitals seems to be a tad thicker than conventional 90 weight oil, around the 100-110 weight mark. Those are my personal opinions, not facts.
maytag commercial dependable care
What agitator did the commercial units use? I like the sound of the agitation with the rhythmic sound of the transmission during agitation. I notice that it doesn't do the clunking like whirlpool does during agitation. I would've assumed that Maytag used the heaviest gear oil.
Which other competitors did?
a little random info
Earlier pittman trannys used straight-cut gear teeth,while the later used helical cut teeth-don't know when the change was made.I think the Orbital tranny started with 1989 production.
maytag a9900 agitation
What is the agitation like on the a9900? I saw a video of the Maytag digital washer from 1991. I wish I could see it going through a regular cycle with a full load of light colors if swestoyz still has this unit.
maytag transmission noise
I notice the Maytag transmissions don't do the thunka thunka thunka thunka noise during agitation unlike GE and whirlpool. Thanks for answering the question of the Maytag gear oil. I could've sworn it was 140 weight oil (34 ounces of it.) This may be why these machines last so long.
There's no way to disconnect it.
The belt that drives the pump is driven by the same motor pulley that drives the transmission belt. When the motor reverses and the spin cycle begins, the pump turns in the correct direction to empty the water out. When the motor rotates in the forward direction, the transmission agitates and the pump harmlessly rotates in reverse. The idea was to keep things simple.
