Hi Rosetta,
I noticed you changed your profile, which is a great step. I also noticed your avatar picture changed, which appears to be, maybe you, holding a cat with a squirrel's head on your body? I think that's hilarious, if it was your intention, to drive home a point that you are not stupid and that it was a misunderstanding, which can often happen on internet forums. You managed to make a point, through subtle humor, instead of being confrontational. I love subtle humor in all its forms. It can often turn a tense situation into a peaceful and humorous one.
I'll be happy to try and help you if I can. You have to understand. I have no idea about your mechanical abilities, so bear with me. Without pictures it's very hard to envision your particular circumstances. The things I can tell you are 1: Unplug the dryer. 2: Get a #2 phillips screwdriver (the most common size). It should fit snuggly in the screw with no play. 3: There are two screws on top of the control panel behind the chrome edge on the front. 4: While holding on to these screws, remove them from the top of the control panel cover. I tell you to hold on to the screws because when they come loose from the machine they could easily fall down behind the machine and you might never be able to find them again. 5: Pull the cover back, up and away from the machine and set it aside with the screws. 6: Get a good flashlight (preferable LED that's very bright) and look down inside the control panel (You may need a step ladder for this part). 7: As you face the dryer and look down inside the control panel you will see the switch directly behind the dial on the front of the dryer. To the left of that switch will be a solenoid, bell, and a little whitish/translucent piece of plastic that connects to the linkage on the solenoid.
On the end of that piece of plastic will be a rivet or screw to strike the bell. Now back to the end that connects to the solenoid. That piece of plastic connects to a bracket that holds it, the solenoid and the bell. Inside of that solenoid is a slug and on the other end of the slug is a couple of metal pieces that stick out from the slug. There are two small holes drilled in those metal pieces and a pin that has been driven down into the holes. This is where the linkage is hooked to the solenoid and the other end is hooked to the switch (that thing that some people refer to as the paper clip looking thingy). When the sensor tells the dryer the clothes are done, the voltage builds up in the capacitor on the electronic control. When the charge is great enough the neon lamp in the control flashes and discharges the capacitor, causing the solenoid to jerk the slug, pull the piece of plastic and the linkage, which in turn rings the bell and the linkage pulls the wafer out of the switch, which turns off the heat in the dryer. At that point voltage is directed toward the cool-down thermostat which runs for another couple of minutes. Once the cool down thermostat is satisfied it opens and shuts power off to the motor and the dryer stops.
In one of your earlier posts you mentioned you could hear a clicking sound, like the dryer wanted to ding but couldn't. You also mentioned that the dryer never stops and just keeps heating and running. Since the dryer doesn't ding anymore and never shuts off, I submit that the little plastic piece that dings the bell and yanks the wafer out of the switch is broken or the pin that is driven into those two pieces of metal at the end of the slug is broken. Anyway, the clicking you are hearing is the solenoid trying to do it's job and something is missing that is preventing it. You won't know until you look. Let me know and we'll see what we can do. In the mean time, here are some pictures for you to look at.
Check reply #5 in this link. It's a perfect picture of what I'm talking about.
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?31676
