Maytag HA606 and A212 tubs
abcomatic
Feb 16, 2006
2,139
Bradford, Illinois
HI washer fans. I have a question. I just finished doing laundry in my Maytag automatics. While washing, the HA606's tub indexed and the A212's did not. Is this supposed to happen in the HA606 or is there something wrong with it? Thanks, Gary
My LA712 does index a slight amount depending on the load size. It's normal for Maytags to do some indexing and it doesn't hurt anything underneath. It probably will need a new brake package if it is starting to get pretty bad (IE more than 1 inch deflection). But either way, it is fine and okay, don't worry about it.
Here is a thread about indexing Maytags (it's not mine, even though though 48bencix also has a LA712.
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?30629
Thanks men for you help. Let me tell you more. lol, here is a confession. I usually wash in my 1964 Easy Spindrier and rinse in the Maytags. In the 606, I had the water level set to large and had a set of my king size bed sheets in them with 4 pillow cases. Lots of water and lots of sheets. I had enough water and the roll over was good, maybe with those sheets and the highest water level is enough to make the tub index? Thanks, Gary
