Maytag LA211
william8
Apr 27, 2024
318
Michigan
I recently have been finding grey/black spots on a couple pieces of clothing, after seeing this thread:
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?29642
I decided to take my agitator out and check. This is what I found, not nealy as bad as the post above, but similar. The last two photos are after cleaning.
After cleanup, you can see how corroded it is, so I don't want to try to take apart further.
So I did a couple test loads (no clothes), removed agitator, and got a little grease/gunk build up around the base of the agitator shaft.
Wiped that off and did two loads of laundry. No spots on clothes, and just a spec of grease. Not sure if the seal is leaking or not. Hopefully that was just gunk buildup, and not grease, as it did come off my hands quite easily with soap and water.
I have never needed any repairs on this machine since buying it new 35 years ago in 1989.
If it is still leaking grease, i may have to finally replace it.
Does anyone know how many Cubic feet this machine can hold? The manual does not say. I've looked at new machines, and even the 5 cubic ft. tubs look smaller than mine.
Wondering what size I would need to come close to this one, as much as I hate to part with it, and buy modern junk.
I could also get a new Maytag seal for $12. Does it need to be taken apart any farther to change it? Or if you just remove the spring clip and washer, can the seal be removed and replaced.
Helical Dr., Maytag leaving grease spots on clothing
You have a very serious problem on your hands. It needs a major rebuild. It may need a new transmission, depending on the condition of the shaft usually when grease starts coming up water is already in the transmission.
35 years is a very good run for a machine unless you want to get into a very costly difficult repair, it’s time for a new washer.
I think this is just a standard capacity machine so it’s around 2 ft.³ maybe 2 1/3.
Any new top load washer you buy is bigger unless you get a little compact machine.
Best new machine is a Speed Queen front load washer, but costly, if you want a traditional top loader again at Speed Queen TC five would be your best Bet if you want something similar to the Maytags durability but a little better performance and much larger capacity.
John
Your 211 has the standard capacity tub. The large capacity tub is 3.2 cubic feet so I'd say yours is probably in the high 2's, maybe 2.8 or 2.9.
It's up to you on how far to dig into the machine. You'll be without a washer for a while but could always find a cheap used one while digging into this one. Some are passionate about restoring like new while others are quick to buy something else and move on with life.
Thanks @qsd-dan. It's odd, when we looked in the stores mine looked larger. I measured, and it appears to be 2.2 to 2.6 cubic feet.
I see you replied in the old thread I linked to above, do you agree this is shot? The link above claimed it was just gunk, not grease. Hard to tell, but it cleaned up easy.
It's starting to rust on the top lid and cover, so I'm not willing to put much money or time into a repair.
Even Speed Queens are getting bad reviews these days. What is a good mainstream brand? I keep reading LG's are the most reliable, followed by Whirlpool and the rebranded Maytags, etc. My wife insists on a top loader, so that settles that part.
Possible new top load washers
Speed Queen is clearly the most reliable brand, has a servicing warranty dealer for Speed Queen for the Washington DC area. We don’t do one warranty call a month problems are nonexistent on new Speed Queen’s and there’s darn few problems even after their 10 or 15 years old.
Online reviews are not an accurate way to get reliability information. You’ll only get the occasional person that complains about a problem they had.
Next Best choice on new top loader would be a Maytag or whirlpool product, which are union made in Ohio whirlpool still the largest builder of top loading washers in the world.
LG Samsung, GE will all get the job done. They’re basically throwaway machines if you have trouble with them, but you may get 5 to 20 years out of them with a few or no problems if you don’t mind the idea of having to throw it away when you have trouble with it.
Your machine is basically shot. You don’t get a buildup under the agitator like that from poor washing habits that’s not mineral buildup that’s grease and oil coming out of the transmission.
John.
That's true for all brands, and the amount of negative reviews I read for Speed Queen has me nervous about spending almost $1500 for one, but I do plan on looking at them.
What is the difference between the TR5 and TR3, they look to have identical specs, but a shorter warranty on the TR3. Seems to me all SQ models used to have a longer warranty?
Whirlpool/Maytag was my next choice, but several sites (not reviews) with service people claim LG is better, which shocked me.
There are only two of us here, we do about 3 loads a week.
Two things- the bad reviews are coming from the TR series which does not clean heavily soiled clothes anywhere near as well as the TC-5.  Second, those that gravitate toward Speed Queen tend to have strong, vocal personalities. The few times a problem does arise (big or small) others end up knowing about it. Speed Queen voices are always the loudest. Vs GE which are typically found in rental units where a break down results in repair or replacement by the property owner where the renter does not have shop or spend extra money for a new washer.
I have a Speed Queen AWN412 which is mechanically identical to the TC5 purchased in 2013 around Halloween.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?49356
Having done between one to two loads of laundry a day because I have a passion for clean clothes and linens my Speed Queen to date has zero repairs with no troubles. The machine has not even physically moved an centimeter for 10 years despite the occasional imbalance caused by user error ie washing a single bathroom rug. It runs just as good as the day I ran its first load.
Performance wise its the best washer I've ever owned. Meticulously cleaned, well rinsed, well spun out lint free clothes in half an hour's time.
Given that you wash 3 loads a week would explain why your Maytag lasted 35 years. My Speed Queen is still running at about 10 loads a week for 10 years, meaning the TC-5 will theoretically last at least 33 years. Speed Queen front load could exceed 50 based on their construction.
Maytag dependable cares are known as one of the most durable, longest lasting washers ever built. The only thing that will sincerely come close is a Speed Queen.
"I have a Speed Queen AWN412 which is mechanically identical to the TC5 purchased in 2013 around Halloween."
Doesn't the TC5 have an electronic board, rather than mechanical timer and solenoids like the AWN412?
We used to do much more laundry with the Maytag. But now it's just the wife and I. I think it lasted much longer because it's a tank, built like the old Speed Queens. Corrosion seems to be the issue now, not surprisingly after 35 years.
Stay far away from the TR series, they don't perform well. The TC5 performs like your Maytag, just with a bigger tub...minus the lint filter and water level control.
The TC5003 uses an electronic board and greatly limits one to flexibility.
Speed Queen does have a timer model, this site has good pictures of it.
https://www.appliancesolutionsmn.co...ercial-top-load-washer-lwn432sp115tw01-white/
You can also try to find a used model locally made before 2018 that has a mechanical timer and lots of great flexibility options.
The TC5 does have have electronics- however the motor, pump, belt, transmission, brake, seals, inner tub, outer tub, suspension, frame, water valaves, and agitator are all identical. Electronic controls in Speed Queens are reliable and are easy to replace if they did give you problems.
Harder to replace components like the transmission and seals are not known the fail prematurely in Speed Queens- they will last without trouble. On the other hand the splutch, shifters and seals in GE and Whirlpool VM washers are not known to be as durable.
The mixed opinions are mostly about the the TR series. Most here agree the TC5 is superior in longevity, durability and warranty compared to any other modern top load washer.
The links you posted while of Whirlpool's commercial and heavy duty line are internally almost identical to their cheapest machines. The differences are only very slight adding little of benefit for the large jump in price. Commercial VMW offerings are IMO nothing more than a gimmick.
I’d recommend an Amana NTW4516FW. I have a sister ship Roper RTW4516FW that is 5 years old with zero problems. These are simple TL’s that are just about as close as you’ll get these days to your current Maytag TL. On the Lowes website these washers have a 89% user satisfaction rate.
There are quite a few YT videos you can watch about these machines. I purchased mine because of one of these videos by an AW member Eugene whose member name is Lorainfurniture. I believe he’s an appliance dealer and repairman. At the time I purchased my Roper Eugene gave these machines a good review.
Eddie
https://www.lowes.com/pd/Amana-3-5-cu-ft-Top-Load-Washer-with-Dual-Action-Agitator-White/1003201568
Hi William,
Yes, the Amana will do a full fill rinse on the Norma/Heavy cycle on the Auto Sense Fill. You can also select Deep Water Fill and it will fill right up to the top and the turn over is just like a traditional ‘Old School” TL. I always use the Normal/Heavy cycle with Auto Sense fill and get excellent results without excessive water usage.
Eddie
Adding onto reply #16
If you want something like the Amana washer but with a few more options, go for the Whirlpool WTW4816FW. I have that washer myself. I was disenchanted with this platform of washer for many years, but this machine won me back over. I was in a bind and needed a washer quickly, and the machines that were my first and second choices felt out of reach financially. So, I took a chance on this one and I'm glad I did. It's similar to the Amana Eddie mentioned, but it adds a soil level knob so the user can increase or decrease agitation time in addition to the cycle that's selected. I find this feature useful because, for instance, I might want the performance of the heavy duty cycle, which is especially accurate on the auto sense fill, but might not want the full 30 minutes of agitation time the heavy soil level provides, so will turn that down to light which shaves some time off the cycle. Eddie's machine is a good one though, it just doesn't have the soil level selector and a few less cycle options, so if those don't matter to you, definitely go for that machine as it's a bit cheaper than mine.
hope this helps.
Ryne
Ryne,
Good points about the soil level selector on your Whirlpool WTW4816FW. I didn’t realize that your machine has this option and it’s a good one to have available.
Eddie
How long are the cycle times on these machines with the full fill rinse? My current machine I set to agitate 8-10 minutes, and the full cycle is about 30 minutes. 25 if I set it to warm as it fills twice as fast.
I figure I have a little time too decide, as no more grease/gunk has shown up after another load today. I removed the agitator to inspect. That's three regular loads after the 2 test loads.
Thanks for the replies.
Using the Normal/Heavy cycle with Auto Sense fill and hot water the cycle takes 74 mins to complete. I’ve never specifically timed the wash portion of the cycle, but I’d estimate it to be between 25-30 mins, including the fill time. The WTW4816FW that Ryne owns may have shorter cycle times using the Soil Level selector set for light to med soil. My Roper RTW4516FW doesn’t have this feature and uses max time for the wash portion of the Normal/Heavy cycle.
Using the Normal/Regular cycle the cycle time is about 34-36mins, but there is only a spray rinse. This cycle is fine for lightly soiled loads, but I prefer the longer Normal/Heavy cycle with the longer cycle time of 74 mins.
Eddie
Wish I could edit, have to wait 30 minutes for a new post?
74 minutes? I knew the new machines were slower, but didn't expect that much difference. Seems like agitating the clothes that long would be hard on them.
They also have this one:
https://www.lowes.com/pd/Amana-3-8-cu-ft-High-Efficiency-Agitator-Top-Load-Washer-White/5014115059
But I don't like the tub, or it's plastic bottom.
Looked at my neighbor's stainless tub (Kenmore/Whirlpool), and realised the stainless tubs on the mainstream machines aren't really stainless. Magnets stick, and they rust on the seam.
William on your old Maytag is far different than the machines like Eddie has. It doesn't agitate as virgour as you Maytag. I bet Eddie could find for you a couple of videos on Youtube that uses this design washer.
Did a load this morning, had a line of grease splatter under the agitator again. No spots on the clothes luckily. I think that only happens if they get sucked under the agitator plate. But it's definetily shot.
I've seen the videos on the Amana, but hadn't seen the one Eddie linked to. That was kinda scary the way he keeps harping on it lasting only 2-3 years.
I did find this video:
He tears it down, and does say the Maytag commercial machines are built better.
I was also ineterested in the Speed Queen commercial model:
44 minute cycle, that's EXACTLY like the cycle in my Maytag. Not sure if my local appliance dealer will sell either commercial machine to me. I prefer the dealer to the big box store. They match their prices, and service what they sell. It's where we got the Maytag.
Here’s another YT video from Lorian Furniture about the lowest priced Whirlpool sourced TL washers like my Roper RTW4516FW. The commentary by Eugene is quite impressive regarding the estimated longevity of these washer’s. Based upon the usage this particular machine has received in a commerical usage setting I expect that my Roper should easily last me 10 to 15 years with the light usage of 3-4 loads a week that our machine receives. It confirms my opinion about these Whirlpool based TL’s.
Eddie
Reply #26
This video was what gave me the final push to give one of these washers another try. As you may or may not know, I owned one before the used direct drive I had for a while. The VMW had a problem after about 6 years where it got stuck between drain and spin. It just buzzed and sat there. Sounded exactly like it was hung up between modes.
An appliance tech told me over the phone not to even bother trying to fix the machine, that it was the gearbox that had failed and it wasn't worth repairing. After learning more about how these particular washers work, I suspect that guy didn't know what the hell he was talking about, and that it was likely the mode shifter that had failed, a relatively easy and cheap repair. I will never again take the word of a repair tech who won't even come diagnose the machine. What a crock. If I hadn't just taken his word for it and instead found someone else, it is very possible I could still be using that same washer today, as it was bought new in 2016. That whole situation also ignited in me an undeserved dislike of these machines for several years.
I think people throw these washers away too prematurely. Many components on them, such as the mode shifter, splutch, and suspension rods can easily be fixed. But since the appliance industry has designated them as throw-away machines not worth repairing, very few of them live out their full lifespans.
Ryne
I did check out the Amana at the local appliance shop. I couldn't get past the way the tub moves around so easily from side to side, seemed very poorly suspended. So did the GE and Maytag/Whirlpools.
I went with a Speed Queen, as stated above. $1150, free delivery & installation, free haul away, free SQ hose extension kit ($89 retail).
Plus they service what they sell, I won't have to deal with any third party warranty work, like I would with Lowes or Best Buy.
I was really surprised. The Amana was over $600 after delivery and buying an extension.
Hit post instead of preview. They dropped Whirlpool products. They said they were having trouble getting product from them during the pandemic. The Amana was a display/demo model, sold "as is". And they only had a couple commercial Maytags left.
