Maytag LA211
New top load washer
Hi William, you definitely Made the better choice getting the speed Queen TC five, while the basic stuff from whirlpool is very good for the money. They are basically throwaway washers because of the low cost. People aren’t going to pay to fix them and they’re only going to have a life of 10 to 15 years.
The thing that Eddie doesn’t mention is, he’s on his second machine the first one only lasted four or five years, The main bearings failed, which would require a complete transmission change. Had he spent the money on a Speed Queen he would be money ahead compared to buying two whirlpools already.
I would still recommend a Speed Queen front load washer on a pedestal. It would pay for itself overtime, especially with an electric water heater and an electric dryer as it spins the clothes so much dryer
Nearly as good a deal would be a Maytag or whirlpool front load washer on a pedestal, they are great performers just may not have the very long life of a Speed Queen front loader instead of getting 20 to 35 years out of a washer. You only get 10 to 15 years whirlpool product.
John
I like the idea of a front loader, but my wife's mother, and sister BOTH hate thiers (not Speed Queens). And they take forever, like 90 minutes.
So my wants a top loader.
And the front load Speed Queens are way too much money.
Speed Queen front loaders and many other US front loaders are fundamentally flawed in not having an onboard heater. A good (real) front load washers allow the wash water to be gradually heated to a user selected temperature/cycle. Also the fact the in long runs the water fill might enough up room temperature when selected to hot.  A Speed Queen top load washer gives you a real unadulterated hot wash.
Another thing I want to point out about the TC5- they do a great wash cycle in about 25 minutes. TR washer takes at least 60 minutes (cycle + heavy wash option) to achieve mediocre wash results. Given that you'd need more detergent to get reasonable results, you'd need an extra rinse (12minutes 30 seconds) you're basically flirting with a 90 minute wash.
Speed Queen front load washers
Are kind of in a class by themselves and they’re faster, my newer Speed Queen only takes 65 minutes on the heavy cycle with a pre-wash and an added third rinse.
There are short cycles that only take about 35 minutes for things that are lightly soiled.
I understand though getting along with ones spouse that’s probably the most important thing and the Speed Queen is quite expensive and it’s overkill for anybody over 60 years old. You’ll never wear it out.
I have four front load washers hooked up at my home and six top loaders , the front loaders get almost all the use Two of them have Boosted heat cycles. I’ve tried them several times. They don’t do anything that as far as having cleaner laundry just seems to be a waste of time and electricity.
Approximately 80% of front load washer sold in the United States have booster heaters. I can tell you from experience that almost no one ever uses them among our customer base most people don’t even know they have such a setting if I pointed out to them
If you have a decent supply of hot water and you know how to use the machine, there’s no reason for a heater in a front load washing machine just another thing to go wrong possibly fry the main board.
John
Front Load Washers With Heaters
I strongly have to disagree with this statement: "They don’t do anything that as far as having cleaner laundry just seems to be a waste of time and electricity."
The best clothes washing results on earth by far take place when cold water is gradually heated up to a select temperature over a period of time. This lets detergents work in stages treating all soil types in the process. European detergent are formulated and have been perfected to work in gradually heated water validating the concept many times over. Further there are tremendous energy efficiency gains by heating a small amount of water inside the horizontal access tub rather than idling a large tank while heat is wasted away in piping. The same benefits of cleaning and energy efficiency can and should be stretched to US front loaders.
If everyone were like me all US front loaders would have at at least a 1500 watt built in heater that would be used in all cycles except a dedicated cold wash only setting. Water would be heated from tap cold to somewhere between 70*F and 195*F depending on the fabric type. Otherwise would be inconceivable, even BOL machines would offer targeted water heating. I hope the day comes when when nearly all cycle start using the onboard heater.
Relying on an external water heater (in a front load washer) is a pointless waste of energy. By the time the cold water is pushed out of the pipes and hot water enters the tub where it becomes diluted the wash water is much cooler than the setting of the water heater, if not lukewarm, defeating the intended purpose.
Reply number 34
I have yet to see any consumer testing agency suggest any other things that you are saying are true machines clean beautifully in water around 100° with modern detergents hotter Water is just a waste of energy and hard on the clothing.
Sorry Chet, you just can’t make up things to suit yourself.
John
If you choose to ignore 80% of the testing agencies, manufacturing and consumer market around the globe yes I may (key word) may agree with you're stance. Till then all the data says onboard water heating is superior.
I'd also like to hear how you're going to get 35*F cold water in a winter climate to get to 100*F without an onboard heater.
You get it to 130 easily with a water heater.
I am in a winter climate, but the well is 90' feet deep. Newer wells are 180' minimum. Water is about 50 degrees year round. Whether it's 95 outside, or 10 degees outside.
A hot fill machine is a novelty here.
We don't use hot cycles often anymore and as our water is heated as we use it it makes no sense to have a hot fill unless you have free hot water of course!
Most of our washers heat from cold ok I know we have 220v as standard but its horses for courses your machines and detergent work very different to ours.
Having had a SQ FL which was wired for 2x2000 watt heaters as it was meant to be hard wired into 30amp supply I simply removed the 1 heater from the relay switch it took a little longer but that was beneficial to the wash cycle,It used to hold the time while it heated which was necessary as it was connected to cold fill only via a Y piece.
The Sani cycle is brilliant for removing stains from whites I cannot imagine never using it but this is my opinion only your milage may vary...
