chef
Active member
I have a 1984 LA612 washer and a 1988 LDG486 dryer.
The LA612 agitator is oscillating at only 90 degrees.
I just picked up a washer/dryer set, 1988 LA712 washer and 1986 LDG712.
Is this common for washer and dryer sets manufactured 2 years apart?
This forum seems to be dedicated for washers only? Both LA712 and LDG712 exterior finish is much worse than my LA612 washer and LDG486 dryer.
Are all the parts interchangeable? The LA712 has more functions and the LDG712 has electronic dryer control which is better?
I'll try and rebuild the Pitman tranny and add a magnetic drain plug at the bottom and it looks a little tight but I'll add a filler plug at the top.
I'll check how well the tranny is balanced.
I read in one of these forums, after June 1986 is when they changed the pitman tranny o-ring design?
I thinking of using Motul synthetic gear oil.
