There's no sensor or electronic control unit on a 412, this design uses a more basic approach where the timer only advances when the heating element is off. It's not as accurate as the electronic version but its fairly accurate and better than timed dry. On the auto dry feature, the timer should advance when the heating element is off.
The basic areas of failure are a dead timer motor, bad timer, bad regulating thermostat, or a weak high limit thermostat that's cycling at a temperature below the regulating thermostat. Airflow problems also contribute such as a clogged or restricted exhaust duct, clogged blower wheel/housing, and stripped blower wheel (this is common at the age of this machine),
Let the diagnosing processes begin....
Select time dry or air fluff. Does the timer advance?
