Maytag Neptune washer and dryer
spaniel50
Mar 5, 2007
73
I would like to see what you guys think about the Maytag Neptune washer. I have posted before about how I just got a new top of the line Whirlpool tl washer and dryer. I really don't like them. Both are very noisy. I had a Maytag washer and dryer that I had for 34 years and both were still working. Even the lights on the back panels still worked. The Neptune is the only Maytag that looks like something from the "real" Maytag company. I have seen mixed reviews on the Neptune. My brother and his wife have had theirs for about 2 years with no trouble. Also have an older friend that has had hers for several years with no problems but have another friend that has had several problems with theirs. Do you think they have worked any of the bugs out of the machines by now?
it's honestly hit or miss.
My aunts have a Neptune set from 1998 and they had a door latch, wax motor and rear bearing failure all under warranty. Since then, it's been running great.
You have no worries about the dryer. It's their same dryer design right after "halo of heat."
I use the Neptune washers at the commercial laundromat and they're wonderful.
Someday, i'd actually like to find a used Neptune set for myself when the day comes.
Just my opinion....
The Neptune washer was rushed to market a year, year and a half too soon.
If Maytag could have done that much more field testing, and done something about the wax motors, for one painful example, it would have been a world class washer. It is still a nicely designed machine, except for the notable (to us) lack of a door window.
I wanted one, in 1997, but I decided to go with the Dependable Care top loader, and I am very glad I did.
Lawrence/Maytagbear
Take it back (the whirlpool)
I had 1998 Neptune washer and dryer. I did have some problems with the wax motor door locks and motor control circuit board. Both replaced under warranty. No problems with the dryer at all. In 2004 I decided to get something new and sold them to my brother. To this day he still has them and working fine.
I then went to Sears and purchased the Kenmore Elite front loader and matching dryer. Kenmore/Whirlpool almost the same thing. I hated them! Your right! They are very noisy! The washer shook the entire house at high speed spins.(Machine was level) It seemed to have very little water in it when going through the cycle. I did not care for the pull out drawer soap dispencer. Trying to pour bleach in the little tiny square you have to have really good aim and very steady arm. The dryer also did not care for. Always had this hum to it,did not like the lint filter,and realy did not like the cool down cycle. The dryer goes into tumble on/off for cool down. What is the point if the clothes are still hot sitting in the dryer WAITING for the next tumble?
After 6 month with the Kenmore's I decided to take them back. Sears was really good about the return (full credit) I then purchased another Maytag Neptune washer and dryer. I love them. Much more user friendly. The washer is very quiet and it is much easier to get the soap in with the soap dispencer on the top of the machine. No drawer! The dryer is also very quiet,drys clothes really well and fast too. The lint filter is much easier to pull out. The cool down cycle is much better,continuous for the first 10 min,then after the clothes are cool will going into on/off tumbling. I have had no problems at all with my 2004 Neptunes.
Jim
Thanks for your comments. I took the plung and ordered the washer and matching naptune dryer. I think I will keep the new Whirlpool set just in case I end up with problems with the Maytags. I will give you an update after I get the Neptunes.
Pleased with the Neptunes
I have owned Neptunes since 2001. No problems at all. They perform well and efficiently. The water here is hard so sudsing is not an issue with any detergent period. The only down side of the Maytag is that there is no window. Makes the machine somewhat boring.
Regardless, if you are thinking of getting a Neptune, do it soon. WP is closing the plant that manufactures them in October. While parts will be around for a long while to come to support both the domestic and commercial market, new machines will soon be gone...
Do It
I waited too long and missed out on the last of the Dependable Care models and now I'm stuck with my confounded Whirlpool DD machine, so get it now!
The current Neptunes are made by Whirpool's daughter company(Bauchnect)in Germany.They are now called the Epic and are replacing the KitchenAid line(Ensomble)of front loaders which Whirlpool has gone 100% professional on.I have that model by KitcheAid and let me tell you,it has been one of the best performing front loading washers I have ever owned.It is very quiet,very efficient,saves water and cleaning aids,Easy to operate and holds tons of laundry.Fun to watch and I went and placed string lights inside the outer and inner door windows!They make it so neat to watch especialy at night.As far as shaking and noisy are concerned,the manufacturers tell you in the use and care instalation books they do not recomend placing their front loaders on any floor above the first or basement.The weight of the wet clothes combined with the rpm the machine is spinning whrether it is level or not will cause serious vibrations because the floors it is on are just not strong enough unless they have a concrete base underneath.No matter what you do,it just won't work.
Laundromat, the current Neptunes are still made in Newton, IA., like PeterH770 stated above. You are correct about the Epics, though, for now. But from what I've been told by WP, some of the newer Epic/Duet/etc production will be moving into a new factory under construction in good ol' Mexico.
back to the Neptune
The last of the domestic Neptunes are mechanically the same as the ones sold to the coin-op market. They are still American made for now, quite sturdy, reliable and functionally robust. It seems for each naysayer out there, there are plenty of satisfied users, including laundromat owners.
Go for it while you can.
maytag neptune washer and dryers
Thanks again for all your help. I was told the same thing by the sales rep. The neptunes are still made in Newton but maybe not for much longer. He laughed and said they are still a "real" Maytag.That is the only reason I went ahead and ordered the washer and dryer. They told me they should arrive next friday or saturday. I know NOTHING about front load washers so I will need to check this website to get some answers about loading,soaps and proper care of the machine. I was wondering if it is better to get the extended service contract from Maytag or my retailer? I called a friend today and she has had her Neptune for over 5 years with no problems. I hope I get a good one too!
soap
Stock up on some HE detergent before the machine arrives, and give away any non-HE detergent that you may have. Non-HE detergent can ruin your front loader over time. HE detergents that were rated highly by Consumer Reports include Tide HE, Kirkland (Costco) HE, Gain HE, and Method HE. Most likely some of the posters here have their own favorites. I am using up a bottle of All Free Clear HE and it seems to work fine, gets clothes clean without oversudsing.
The new Maytag Neptune washer and dryer are to be installed sometime between 8am and 12 Thursday July 5th, They actually came in early. I will sure let you guys know what I think after they arrive. I will be getting them installed 33 years almost to the day I bought my first Maytag "806"pair and they are still working perfectly at the old house. Even the lights work in the washer tub,dryer drum and the lights on the backsplash. I would say that is pretty good service!
Rob
