Maytag Performa Dryer-Who made this one?
travlincub321
Sep 25, 2009
534
Model PYE2200AYW
Serial 10776853WY
I picked this up today from a quadplex thats being torn down not far from my house...
I had a choice between this, a Frigidaire from 1997 or a BOL Hotpoint from the early 90's...
My one question: Why is this thing yellow?? There are like heat spots or?? yellow staining on it.. From heat or something??? Runs great..
Wanna know who made it and if i should sell it (electric dryers arent popular here)or keep it until i find something better..
Heres the front.. Not sure if you can see the yellow part..Also there is some paint.enamal missing from the inside
Now im trying to find a picture of a norge made maytag dryer.. my door handle is on the upper left corner.. Just ran a load through it on "low" (2 pairs of jeans anf 6 tshirts) it dried fine in 45 minutes
So is it electric?
Looks like it has been burning dust.
If it's gas, I'd guess the yellowing is schmutz from the combustion process.
Perhaps there was a plugged filter or an excessively long duct run. I'd wash the filter in soapy water in case the prior users used dryer-sheets, which are a huge fire-hazard, detriment to performance and not generally envirnmentally "green".
I think before i use it again, i need to take it apart and clean it.. I pulled the timer knob off and ewwwwwwwwwww... It is electric
Glad to know that...Had a small hope it was a regular one.. Whats funny is that the other norage made maytag i know of looks diffrent than this one
Wanna know who made it and if I should sell it (electric dryers aren't popular here)or keep it until I find something better..
Does that mean gas is more popular or are dryers, in general, not all that popular?
Gas is far more popular..After house hunting with my sister (shes moving here) and looking at alot of places... 85-90% have gas dryers.... And most are either GE or Whirlpool.. The thrid and fourth place are Kenmore and Maytag...
Im also thinking the yellowing at the back is burnt dryer sheet residue. It happens with fabric softer to but only slightly. Dryer sheets are very waxy like. Bad for skin,dryers and the environment lol.
The
yellow discoloration of the drum and brown rusty looking heat inlet both point to a restricted dryer exhaust vent system.
The surfaces become overheated from poor air flow through the machine. The inlet grille "rust" is really melted and/or burned on synthetic fibers.
right now its just sitting unvented in my garage and it blew a crap load of lint out... i did wipe the inside out with alchol
Popularity of gas depends on what neck of Nevada you're
Up here in Reno, electric seems far more popular than gas. The house builders will run gas to the kitchen, furnace and water heater BUT not the few feet to the laundry room unless requested. Very FEW will have both 220v and gas available automatically. Plus, Reno also tends to have a large 'transitory' population and electric hookups are easier to find. Once you get out into the 'boonies', then you see more gas units in the form of propane units.
That's a nice Herrin, IL. built dryer. Very popular unit and relatively easy to work on. I see quite a few with yellowish discoloration (if not outright cracked) on the left hand side of the console right near the top as that is right where the element is and too much heat messes with the plastic usually due to poor venting. Just use a putty knife to pop the top clips along the front and disconnect the front panel. It's amaizing just how much crap builds up under the filter right at the blower. The door gaskets are cheap and a piece of cake to install. As the Herrin dryers can be touchy about their airflow, the gasket should be done...
RCD
Thanks... I orderd the gasket and it will be cleaned out tonight.. I am lucky in the fact i have both hookups i take it
cracked on the left hand side of the console right near the
Isn't that the truth. We see so may like that. I would say 80-85% that come in are cracked like that. These dryers were so much better than the washers.
