dustin92
We have a Maytag performa washer, and I thought the issue was our water, or my loading/ seperating techniques, but now both have been ruled out (washer downstairs is performing well with the same conditions). The clothes are coming out dull and just overall not looking clean, and the water looks filthy gray/brownish even on white loads. I know we have an issue with the water coming out gray in the kitchen, but the water looks clean and clear as the washer fills. I just started a load of whites/ light colors, and got dirty gray water as soon as the agitation started. I have used several different detergents (currently using arm & hammer liquid) with the same results. The machine is getting plenty of hot water, and appears to be agitating properly, although it seems a bit slow to me, and the 2 piece agitator is functioning properly. It sounds pretty normal, a swishing type shhhh..shhhh...shhhh sound, and it is spinning well. I am completely stumped as to what is causing the problem. Any help would be appreciated! Thanks!
