Hi everyone I haven't posted here for a while but I have enjoyed reading all the threads and I always learn a lot from all of you. I currently have a problem developing with my Maytag A806. Here are the symptoms:
1. The machine fills to the first row of holes but the water is down to the third row by the end of the wash or rinse agitation.
2. Slight burning rubber smell during spin drain.
3. The machine is slow to spin drain and sometimes is not completely drained by the end of the cycle. However sometimes it performs perfectly normally.
4. The washer is not leaking from anywhere that I can see, and I have removed the front cover to check.
I am wondering if I need a new polly pump or if it is another problem entirely. The thing that puzzles me is that the washer often works fine but the problem is popping up more and more. The machine is still under warranty from West Coast Appliance where it was rebuilt, but if it is a simple fix I will do the repair myself. Any help you can give me would be appreciated.
Thanks
Liam
Thanks
Liam
