rainislandman
- Joined
- Oct 18, 2008
- Messages
- 12
Instruction ... remove the "metal sleeve collar" on the transmission shaft ...
Following a set of instructions copied from < http://www.applianceaid.com/tub_seal_replacement.html >, I'm now stuck at the above step.
The "metal sleeve collar" (being the inner bearing) that fit's over the transmission shaft doesn't want to be removed. I guess being in place since the washer was new in 1970, it's stuck.
What's the "trick" to unsticking it?
thx
thx
