That first set is about as BOL as you can get. Those were sold at a store called McDuff's here when I first moved here. The 2nd set, that's early Dependable Care model and pretty rare as most were the all white control panel. The washer is about TOL, if not TOL. 4-speed combinations and 4 water temp combos. I am unable to see the extremely left side of the control panel to see if there's the 2nd rinse and or the energy saver rocker switches. It's a shame the dryer isn't the exact model match. That would have electronic control dryness sensing as well as the moisture monitor display on the panel.
