Maytag (Speed Queen) Dryer Repair Question
jaytag
Dec 14, 2018
5
Atlanta
Ok, so I have trouble shot the issue with the Maytag pair I picked up on CL. The dryer works but it makes a screeching noise when it tumbles. Is this a roller issue? How can I fix it. I would like to sell the set and get some money back out of them. Model SDE3606AyW serial is 11126166CV I am assuming if was mfg in 2005. Anyone?
It could be one of the support rollers but my money's on the idler pulley. I've replaced quite a few on this design. Also, before you tear it apart, check to see if you have a screw, pin or something of the like stuck inbetween the drum and the front or rear bulkhead in the felt seal. That's more common than you think.
RCD
