hjelle1
Member
We have a Maytag Washer A608 in good condition. It spins and removes water fine but does not agitate. With the belts removed I can turn the large center pulley in both directions. One way spins the drum and the other direction agitates as it should. The motor turns fine in the spin direction but does not run in the reverse direction. I tried several different locations on the timer and none activate the agitator. Are there diagnostics I can do to determine if there is a problem with the motor or the problem is some other electrical component? If I can determine it's the motor, I can take it to a local electric motor shop to see if repair is possible. If it isn't the motor, which component would be the most suspect and how can I test it?
This video explains how to test the motor with jumper wires on a newer Maytag but even though the wires are the same color as ours, the connections on the connection block on our motor are all in a line and have no markings.
Is it safe to perform this test on ours using the same color wires?
Thank you very much,
Dean
Dean
