nuwash
Member
My previous thread in Shoppers Square showed i found this avocado set on FB Marketplace. The unspecified motor problem was further explained by the seller as 'it won't spin' and an 'electrician said it had a short in the motor'. That explanation seems unlikely since I discovered that both the drum and motor turn freely by hand but the pump won't budge! Its stuck fast and the belts are loose. Anyhow, other than a pump and belts what should I do on this machine?
