Maytag washer "automatic" button
zipdang
Apr 22, 2004
508
Portland, OR
My grandparents and great-grandmother both had Maytag washers like the one Drmitch has, with the center-mount knob and lighted control panel. One of the machines had the clear glass cycle knob, and the other had the chrome one, although it's been 20+ years ago and I can't remember who had which machine. Anyway, I would swear that one of the washers also had a big wide button marked "automatic". Is that possible? If so, what settings did that control: only speeds, or speeds and temperatures? I'm sure that button existed, but I can't recall seeing another machine with same feature.
Also, my grandparents never had the matching Halo-of-heat dryer. They had an old slant-front Westinghouse with a rear control panel. It had big, "groovy" 60's-like multi-colored toggle-switches for temperatures, and the largest top-mount lint filter I've seen. I haven't seen another dryer like it in anyone's collections. Does anyone have pictures of such a creature, or possibly of the matching washer? (Unconfirmed rumor has it that the Westy washer died and was replaced by the Maytag.)
The Maytags with the wide "Automatic" insert were the single-speed models. If a two-speed then two buttons "Regular" or "Gentle" would fill that space. -Steve
I think the machine without the "automatic" insert had a button marked "wash and wear".
When did Maytag stop using "damp dry" and start calling it "spin"?
Big Automatic Button
When you pressed that big Automatic button, the wash would spin during the spin cycles, otherwise a wringer popped out of the side of the machine and it waited for you to wring the clothes between wash and rinse. :)
Another good answer from Robert. Hahahahahaha. I haven't had so much fun since...........Oh forget it.
Thanks for clarifying that, Robert. I now have the mental image of a wringer springing out and knocking my tiny little great-grandmother over! :)
Big automatic button
My parents had one of these machines with the automatic "filler" where the speed selectors were. also the little " on light" over the timer dial had no bulb behind it, I was dissappointed and only at age 9. :-)
