Hello Group - I just joined today as I acquired a set of Maytag washer / dryer.
Both work fine. The washer is in need of some help. I don’t know what to do. The wires had been chewed off of the two fluorescent lights. If someone has a p142 model maybe you can help me connect these wires to the correct spot.
Second question : it seems there are a lot of lights - I found (2) fluorescent lights tubes, 1 tub light , 1 glass dial incandescent light .
The second Fluorescent light brackets did not have the Fluorescent tube and was detached.
Thank you
Thank you
