geoffdelp
Bobby ... you're not reduced to a toad!!
You push in on the release bars to get them to release. You turn the reset on top of the wringer one quarter turn "clockwise" to reset. If the rollers are locked up (about an inch or so space between them) you then press on the release bars and turn one quarter turn "counter-clockwise" to drop them down and then one quarter turn clockwise to reset.
The center knob you are referring to is the agitator start knob? You don't have to pull with all of your might, but you should pull it "quickly" to start the agitator.
Is your machine a pump model? You can tell by the Off/On lever on the right side of the machine by the drain hose. If there is no lever, then you have a non-pump model and you simply lay the hose down to drain the water.
Does that help?
Geoff
Does that help?
Geoff
