Good evening!
This is my first post here, though I've read several threads and found them very helpful! A few weeks ago I acquired an N2L pump model at a yard sale--I've always wanted one, and this one was in good shape for a good price. Everything seems to work, and nothing's seized. But...
Oil is leaking from the wringer shaft where it connects to the transmission shaft (at a 90-degree angle, concealed by one of the legs). It's stained all down that leg, so I know it's had this problem for some time. Thanks to information I found here, I learned that this is a common, and requires that I replace the leaking seal. The trouble is, I can't separate the two shafts, no matter what I try! I took the bolts out of the leg, thinking that might free it up. I tried coaxing it with a rubber mallet. I even poured boiling water on the old seal, hoping that might loosen things up. If this were a car or something, my next tool would be a torch--but that's out of the question here!
I was hoping somebody might have an idea that I could try. I'd love to stop a leak, but don't want to cause more damage in the process!
Thanks, Adam
Thanks, Adam
