Maytag Wringer Washer E2LS - Oh no! I think I broke it!
Manyhats
Sep 13, 2025
I was using my Maytag wringer washer (E2LS) yesterday and I had too thick of a piece going thru the wringer. Instead of turning it to run it backwards (It has a foot pedal safety actuator that I hate using) I pushed the release and the thing popped up. It's now like gapping open and I can't get the reset handle to close it. WHAT did I do?!? Anyone have an suggestions? 20251104_072151.jpg
I think you need to turn the white handle on top of the wringer to get the rolls to tighten down again. If that doesn’t work try lifting up the top of the wringer an inch and letting it gently drop back down, that may get it seated properly again, then retighten it by turning the white bar on top of the wringer.
My Mom bought a new Maytag ELSP in ‘69, the first year of the safety foot actuator and the dealer told Mom that most customers hated it and that he could disable it before delivery if she liked. All he did was unscrew the actuator tube from the back leg and plug the hole with a stove bolt that fit the hole by screwing it into the hole. Voila, the wringer worked just like the older models without the safety actuator.
Hope that you can get your wringer rolls back together.
HTH,
Eddie
You discovered how to separate the rollers apart between wash days! Push and hold the turquoise bar in while turning the tension lever on top counter-clockwise. The wringer cap should drop in place. Happy wringing ...
