Friend called me re tub remained full of water and laundry. Would not pump out. I shop vac'd the water out then tried spin position and it did spin,could see remaining water in pump swirling around, tried it again couple minutes later, it spun until motor overheat, I assume, kicked it out.Tried low water level, no clothes and it agitated very slowly for brief time until motor kicked out again,hot smell. Transmission pulley and pump pulley with belts on motor both easily hand turned. Can we correctly assume, as used appliance seller told me, that it is most likely the motor going, maybe start windings bad? The local parts dealer quoted $200.00 Cdn. for motor and a jumper kit-whatever that is.A610 series1 #803980LP Assuming motor-used dealer/repairer said about $110. labour $200.motor=310.or so, he sells used direct drive Whirlpool/Kenmores for $329. including a 1 year parts and in home service warranty.same money just about. If motor is plug and play I would attempt install but jumper kit? scares me. Comments please and what would you advise.
