Mechanical Timer
Unfortunately...
No mechanical timers that I know of anymore, not even on BOL washers. Even the cheapest washer I can think of off the top of my head, which is the Amana NTW4516FW made by Whirlpool, has electronically driven knobs and a push-to-start button. Control boards are the new normal, my friend. :(
Tragically, none that I know of. There is consumer demand for timer models as this post proves but unfortunately appliance manufacturers have moved past "freedom of choice"
The only option I can think of is buying a used model.
One can only hope that one day someone will come to the rescue offering machines that people actually want.
At some point it just became unprofitable for mechanical timer producers to remain in business I suppose. When Whirlpool among others stopped using electromechanical timers on their dishwashers, washing machines and dryers there went a huge customer base for Midwest Timers and rest.
“We needed a different product,” said Bruce Chapman, co-owner of Midwest Timer. “Electromechanical timers are more or less going away. They’re going to continue to decline.”
The decline stemmed from appliance manufacturers “obsoleting” electromechanical timers in favor of digital components. While electromechanical timers still had a place in commercial applications, Chapman and his partners realized the business was “never going to grow.”
https://mibiz.com/sections/finance/deal-for-lectro-breathes-new-life-into-midwest-timer
Decent mechanical timers faded out with the 90's. Superb mechanical timers died out in the 80's, with a few of them in the 70's. As I mentioned in the past, if a timer isn't somewhat difficult to turn while making a racket dialing in a cycle, it ain't gonna last very long.
The timer on the parents' 1994 KitchenAid is what brought it down at 18 yrs.  It was always hard to turn, lotta cycles and functions crammed into the mechanism.  Super Wash was the real-deal Whirlpool version with prewash, pause/soak, partial drain/pause, continue into Heavy.
18 years is a pretty good/average run for a early to mid 90's washer. What failed in the timer, was it the timer motor, escapement, contacts, or something else?
The shaft broke loose from the cam mechanism.  Could be turned only by grabbing the dial skirt behind the plastic slip-shield.  Replacement timers were available at the time ... but the porcelain top quality wasn't good.  The laundry room is an outdoor room adjacent to their carport, not climate-controlled and rusting had occurred through the years.  I had a refurbed Kenmore 90 available to swap-in.
QSD-Dan, the parents' laundry room is not heated/cooled but is not directly open to weather exposure.  It's a separate room with a door and small single-hung window.  It has a single-bowl sink, storage cabinets, one of the two water heaters, washer, dryer, chest freezer.
@dadoes: Indeed! Dryers still have EM timers. IMO its not so much that electronics have become vastly cheaper than mechanical timers but rather modern appliances require variable functions modified upon varying sensor inputs due to the reduced amount of material and mechanical components compared to older appliances.
If washers still had brakes, dampened suspensions, transmissions, ect- if dishwashers didn't have to purge air out of the sump, take air expanding inside the tub into account, turbidity based fuzzy logic, ect I think new appliances would still have mechanical controls.
Reading up about Midwest timer makes me so sad. They perfected Whirlpool's timers with excellence, and seeing a masterpiece, along with the company abandoned, is undeserved.
I would give anything to be able to contract with them adapting timers into new models of appliances. One can only dream.
I recall someone, somewhere complaining about inconsistency of moisture sensors on small loads due to insufficient contact with the sensor bars but I couldn't find the discussion here via search.  And/or a mix of disparate fabric types throwing sensing askew.  Preference for temperature-based autodry was expressed, or timed drying in some instances.
I had a tragedy today via overturning a bowl of salsa on my leg/jeans while sitting in my office chair.  I wrapped the fleece throw that I keep on the chair around to prevent salsa running down to the floor while I arose and walked outside to remove the jeans and flush the salsa off with a hose.  Thus, both the jeans and throw needed to be washed.  Together.  On the Stained/Tomato cycle in the Aquasmart.  And dried.  On moisture-sensing autodry.
One pair of jeans, and one synthetic fleece throw from which 1,010 RPM spin removes an appreciable amount of water.  An already almost-dry throw with one pair of considerably heavier jeans.  Will they dry OK together?
I have no details on how F&P formulated their sensor algorithms but the Aerosmart produced one perfectly dried pair of jeans along with the fleece throw, using the Jeans/Workwear autodry cycle.
Thanks for all the feedbacks.
Yes Alex, SQ still offer them in their On-Premises Line but not for long. It used to be available under the Huebsch brand in their Light Commercial Laundry line but no more.
https://huebsch.com/products/light-commercial-laundry/top-load-washers/
Jerome (reply to #16 post): Same here! Nice to see someone of you generation with that POV.
I shall miss the versatility. To be able to select the time of a wash cycle (vs turning a dial to "NORMAL"), the ability to repeat any part of a cycle as I see fit. To prolong wash time, repeat spray rinces, a 3rd or 4th rince with just the twist of my wrist and so on... Hope the parts will still be available should my ZWN432 need it.
Electronic knobs have a nice retro look. Touch panels look good and some DO offer lots of options (that most people won't use). We are just hopeless romantics.
On another subject: Prices and profits can only go up. For cryin' out loud, the matching dryer of any SQ models has the same MSRP as the washer! Now that's profit my friends!
I've mentioned this before, but...
Since we're talking about mechanical timers here, I'll add on that, at least in my experience, a mechanical washer/dryer is waaaaaay easier to use for someone with a visual impairment. Take this from personal experience as I've used both. As far as I am aware, the only control board type modern washers I can easily use are the BOL VMW machines because they are all electronic knobs, only button on the thing is the push to start, but I don't like how quickly they break down among other irritations about them. So the issue with modern electronic machines is that I would have to go super basic and realize I get what I pay for, or I'd have to go clear up to near top of the line front load units and hope that the smart phone app is accessible enough to make the touch screen on the machine usable for me. The middle of the road options often don't work out because the touch screen is there but the WiFi connectivity functions aren't advanced enough on those machines to use the smart phone app as an aid for cycle selection/modification. On the other hand, a mechanical washer is super easy to adapt for my needs. For example, on my 2005 Whirlpool washer, all mechanical, I put a small piece of tape on the 14 minute position on the regular cycle, which is what I most often use for towels, and one on the 10 minute position, which is what I most often use for clothes. Another piece of tape on the pointer so I can line them up by touch and voila! Easy as pie.
Until electronic modern machines are accessible and usable to all, I can't in good conscience say they are a better option.
Glenn, It may have been my post about sensor dryers not able to dry small loads. I was actually referring to my current LG daily driver. My previous sensor dryer was a top-loading F&P, which was incredibly accurate, regardless of the load size. When my late partner and I bought a new home, we gave the set to my niece. With only a couple of minor repairs, the Aqua-Smart was still working after 15 years of use.
Actually they only make one as of today and that is the LWN432SP115TW01, the AWN432S models has since been discontinued so that website hasn't really fully been updated. This was confirmed to me by a distributor shortly after my last post on this thread. Also, buying one online would be a risk. There's a reason why Speed Queen would encourage you to buy from a local dealer. Below are videos of the LWN432SP115TW01.
