Sudsmaster - Sensitive on the US Miele machines is equivalent to teh water plus options on worldwide machines, which is an extra rinse and higher water levels.
My machine has the soak option whilst these don't I believe, but mine is definitely the most flexible machine I've used and I have to say apart from water plus I rarely use the other options - they're just not needed even with heavily soiled whites. As Nathan said, temperature and spin speed is changed via the corresponding option underneath the display - no more complicated than a mobile phone interface. It definitely is more flexible than the Bosch Nexxt machines, which are the only other high capacity frontloader there is out there from a premium German brand. If you ask me, I think the Bosch machines are quite dumbed down and are no where near as flexible as these Miele's.
The Miele's I use actually have lots of additional cycles (Outerwear, Sportswear, Proofing, Dark Garments, Curtains etc) , and I have to say that the cycles I use mainly are Cottons, Minimum Iron and Denim- no more flexibility really is needed. BTW the Mastercare cycles option (labelled as Further programmes on the TOL Miele's here) brings up a further menu of 10 or 15 programmes - that doesn't shout out dumbed down to me.
Jon
