Haha lol the f
So this manual for your DW is somewhat typically misleadingly strange.
Your consumption values for hot water connection are listed higher since they include the values for heating the water externaly according to labeling practices which shows that if you have electricly heated water, there isn't much sense in hot water connection anymore.
Even with a gas heated hot water supply I would argue that the difference is marginal heavily depending on the length of pipe run.
These DW have fill levels of less than 3l, probably pretty much spot on 0.75gal.
So any pipe run of more than 30ft will probably not even be completly emptiednd even with warm water connection, the DW still uses about 50-75% electricity compared to cold water connection.
So I was confused a bit at first.
Now, cycle wise, there is some things interesting as well.
Your QuickIntenseWash will for sure use a significantly higher water pressure as its fills are somewhat higher as well.
It has the same number of fills as your "Economy" cycle (which btw isn't much off the EU "Economy" cycle from the same Miele generation) and uses 2l or half a gal more.
Our DW over here run the QuickIntense in 1h both on hot an cold water connections, with yours cold water is about 15min longer. That extra time might help with some more dried on dishes and depending on detergent it might boost enzyme activity.
For drying you might want to add the extra dry option and the lower intensive if avaible might make that cycle suitable as well for more common place loads.
Your "Normal" cycle is neither a true sensor nor a true economy cycle.
It is sensor based on the account of selecting wheather to prerinse or not but not much else.
Usage data is about where an average Sensor wash would land.
It should perform decently for day to day loads.
It is a shame that the sensor cycle lands right at the last spot of selectable cycle.
No joke, that is still the most advanced and versatile sensor cycle out there.
Yours even goes down to less then 2gal (that is basicly no load, runs main wash and final rinse with minimal heating and water pressure).
Don't be afraid if it says the intermediate rinse is optional.
It pretty much never skips it, ever.
The main wash can go much hotter and much more intensive pressure wise compared to the "Normal" cycle as it has much more freedom in what it can use.
It's never wastefull but far more activley adjusting than lets say a Bosch.
Dunno if you have the machine connected to hot water, but if so, make sure to switch of the EcoTech heat exchanger.
This saves time and will be more efficent (the heat exchanging on a hot water connection machine usually just wastes energy).
Loading wise I do load cuttlery handly out as well. Much easier and quicker to load and undload.
I split my cuttlery rack on the Bosch into quarters, starting to load from each corner basicly, with one corner for each kind of cuttlery (fork, knife, spoon, small spoon) and then add stuff like small knifes in the middle on what ever side will be less filed (for me on the spoon side basicly).
Lower rack in these is somewhat of quite a learing curve.
Depending on how large your larger plates are it is either smarter to load them in the back MultiFley area of the fron spikes.
Smaller plates don't extend into the front area of the MultiFley system, so they would go front row for me with large plates left outside, small serving plates left middle and deeper plates like soup dishes to the right loaded from inside outwards.
Then pots and pans and bowls would go overlapping the back with perhaps some mugs and cups placed as well.
If your plates are larger, just slot them into the MultiFlex area and load pots and bowls in the front with the tines collapsed or not as needed.
If you don't have many plates bowls can be stacked into the Multifley area as well.
So can cups and mugs as well.
I alsow found that when loaded orderly, these can fit 4 rows of cups and glases in the upper rack or even 5 if you are willing to just load over the tines.
Cups and Mugs actually make great resting spot for bowls and such in the lower (and upper) rack.
Main thing to keep in mind is that anything the water spray can somehow touch will get clean 99% of time if it isn't particulary heavily soiled.
I am somewhat contemplating if a Miele or a Bosch can fit more.
I still think that my self made saying that Bosch machines are better for oderly loading with simmilar loads from loads to loads while Miele appears to better for often changing load scenarios.
