Mexican EASY Filter Flo washer
English instructions
Is the lid a replacement? It has instructions in English on the bottom.
English Instructions!!!
I know it´s amazing to have english instructions on the lid, but let me tell you that it´s the original lid all EASY washers come with. If you take a look on the insides, you´ll find that it´s a GE using EASY name and the only thing that comes in Spanish is the control panel, otherwise everything is English. I guess this EASY model was produced at the same time as the lasts GE filter flos. They were available from 1994 to 1998 when the model changed again for the one you have at the moment (double duty agitator) but with the EASY brand. A fried of mine owns an EASY dryer that´s about 25 years old which has a label that says it was made in Ohio. So maybe USA produced the exact same models but in Spanish for mexican population. On the other hand, EASY washers until 1999 were made in the US. The first model available here in Mexico was the EASY Golden Line (before 1980)] which I will look for and take pictures to show you. It had the spirilator agitator and the spining basket didn´t have holes on it. It drained water through a center huge hole under the agitator and had a spin drain as well. They never had a water level knob, instead they had a push button that said "push to operate", which means that if you wanted to have a small load, you must have waited until it filled to the level you wanted and press this button, tha washer was going through the wash cycle and then you´ll have to return on the rinse to push the button again. For me, it was a nice function since it made me return and return to check the wash. After 1999 EASY washers begun to be produced by Mabe company and the filter flo model dissapear.
Buenos, Que pasa? Digame por favor...
No entiendo tan mucho Espanol.
What is the translation of "Ciclo de Lavado Energico"
This is the double-rinse heavy-duty cycle on my Filter-flo; surely not an "energy-saver".
Muchos gracias.
