Mexican made Automatic EASY Golden Line Washer
ultramatic52
Member
Dec 30, 2021
6
Mexico City
The washer I´m describing is 35 years old. They were built in Mexico in the mid 70´s. This model is a AD298, it´s the most complete model. I will describe all the control panel then add some pictures and videos from a washing cycle. From right to left we first have the control knob, it has only 3 washing programs: Regular cycle (with 15 to 5 minutes agitation, spin, rinse, last spin (it lasts about 10 minutes)), Delicate cycle (with 3 min agitation, spin, rinse, last spin), Prewash (with 5 minute agitation and spin), then we have the water economizing push bottom (by pressing it while it´s filling you can make the washer start its agitation and stop filling at any time, it can even start without water, this means this washer has only one automatic water level that can be modified at any time; then we have the wash/spin speed selector, it has 4 combinations normal/normal, normal/gentle, gentle/normal, gentle/gentle, beside is the wash/rinse water temperature selector it has 5 combination hot/cold, hot/warm, cold/cold, warm/warm, warm/cold, at the end it has a the soaking selector using this you can soak your clothes from 15 minutes up to 20 hours, this could only be used in the regular cycle, you select the time you want it to soak while its filling, and after it´s full the agitation will not proceed until the soaking time ends.
As you can see it uses the spirilator agitator, its tub doesn´t have holes, it has only a hole line on the top of the tub where water drains while its filling to fill the outer tub or while it´s spinning. A curious thing about this washer is that the outer is just filled about 10 cms instead of filling the whole tub. This is done to make the Filter Flo work, and while its agitating water keep going through the holes avoiding the outer tub gets empty so the water keeps recirculating. (I´ll post some pictures later of its insides).
W-O-W. The rumor is true. Easies are alive and well in Mexic
Speechless, here!
Thank you for a gorgeous washing machine.
What an awesome machine!
I agree with Greg! It has the best of all worlds!
Thanks for the videos!
Brent
Doubt for appnut!!!
Unfortunately there is no spray rinse available in this machine. but to be honest is not necessary it rinses the clothes very good!!!!
Thanks to all!!!
I'm filling very excited about everyone comments, because as well as everyone in this room I love my machine, the figure, performance, and type of washing is fantastic, hope everyone keep enjoying pics and videos, thanks to all again, an if anyone have questions I'm here to answer all of them!!!
That definitely the signature agitation of an Easy automatic washer! Cool machine!!
Easy!
Great video and very nice design. It looks to wash really well. The rollover is great. I like the way it spins also. Does it do a deep overflow rinse?
Thanks,
Peter
Wow that is cool!
Ugh that Easy Automatica is absolutely beautiful!!!!
I'm assuming that is Speed Queen made transmission and drive, and yet it seems to appear that the clutch brings the tub up to speed in this machine a bit slower than a Speed Queen. I wonder what the mechanicals are??? The bleach dispenser is shaped almost the exact same was as my 1962 Easy Velva-power washer.
Ultramatic, thanks for sharing a new machine i have never seen. In Cancun, I remember seeing a coin-op with what looked to be wascomat machinery. alr2903
