Worth Salvaging Only If You Have A Similar Model
That uses same parts, and or are willing to take on swapping out the bearings yourself.
Fully operable Miele washing machines have been offered for less, much less and still had no takers. I wouldn't give more than $50 for this unit and again that is of one has use for the parts and or is certain has the chops to do the repair.
A front loading washing machine with shot is nearly worthless IMHO. You cannot run the unit as is so what is the point?
MieleUSA does not do bearing replacement in the field. Unit must be shipped back to Miele's shops in Princeton, N.J. Normally Miele will decline to do such work at all except under warranty or if the customer insists. Just the shipping back and from New Jersey can be costly, then you have parts and labour....
