Miele Excella II
Temperature Selection
I noticed in the manual that you can change the temperature from C to F. Can't find where the temperature is ever displayed on the control panel, so what is this used for?
Anyone have a clue?
Malcolm
Hi
I have a G 1832 (Euro version of La Perla II). I do get a temperature on the control panel with most programmes (e.g. 'Forte 65°' aka 'Heavy Soil' etc).
You probably don't need such 'intensive' programmes for the types of load you showed in the picture, mrb. The Sensor wash, the Energysave 45° (i.e. Economy) or the Standard 55° (you might want to add 'Soak' to that) would take care of them no problem, guaranteed!! :)
Temperature display
Hi mrb,
the reason you don't get temperatures because the software is set to the USA version. On my G2830 it shows temps, but I changed the country version to EUR, which changes the programme sequence on the Normal cycle. The country versions available are
AUS-Australia
JPN-Japan
USA
EUR-Europe
SER-South East Europe
I/E - Italy/Spain
What happens when you change the country is the programme sequences are modified for that country's particular requirements. For example if you set the country to I/E, the sensor wash temperature range goes from 45 - 70 degrees C vs a max of 65 in the EUR mode. The reason being in Italy and Spain they need to tackle more stubborn starch soiling such as pasta and rice
I now have the G 2834 and the Sensor wash has been modified from the first version. I like the Turbo function which gives a hotter wash and cuts the programme time down.
Hi Mielerod69
according to my (Italian) instructions manual for the G1832, the Sensor Wash programme has a temperature range of 40-65°.
Malcolm
When I first purchased my G2830 I called USA Miele technical and asked about the lack of temperature display. They said the same thing that Rod has shared - country dependent. I tried changing the country code to EUR and ran a few loads, but found that the program durations increased and I got no better results with the increased time, so I returned to the USA setting.
I would also suggest running that same type of load with the sensor Wash program just to see what the results might be.
I noticed the font size of the words on your display. Do all of the screens use that same font size or is that only used on the options screen?
Screen Fonts
Ya know... I haven't noticed a difference in the size of the font on the display. So, I assume they are all the same size.
Once I have tried most if not all of the programs, I will probably settle for a select 2 or 3 that will be used on a regular basis.
Malcolm
I really like the removable
tins/racks. This would be very helpful when washing large pieces. What I like especially with this Miele is the cutlery rack. Does this special rack eliminates spitting since the cutlery does not touch each other?
John
Malcolm, do you find the Miele cleans well when you double stack items, like say, a bowl over a cup on the top rack? Or when dishes in general just overlap each other on either rack? Some modern machines seem to have a problem with this!!
