Miele G7166 Dishwasher Update
labboy
Jul 22, 2010
288
SD, CA
I was able to run our new Miele G7166 dishwasher a few times this weekend with houseguests and cooking. This is my first Miele dishwasher and I’m as impressed as I am with our Miele washer and dryer.
Aside from setting the machine with the local water hardness, the only setting I’ve changed is to add a second interim rinse prior to the final rinse.
There are a few quirks I had to learn about loading. But, once I got used to them I realized that you can fit a lot of dishes in these.
AutoDos detergent dispensing is great. Everything comes out gleaming. Especially pots on the Pots cycle. It seems to have a lot of oxygen bleach because I have some coffee cups that have never looked whiter.
AutoOpen is awesome. We run the dishwasher at night normally so when we come out in the morning the dishes are almost totally dry (water remaining is only a bit on the top of a plastic container or dog dish).
The only thing I dislike about this machine is it often asks you to confirm selections with OK. It gets annoying. If you don’t acknowledge it, it will beep harshly at you.
However, despite the minor issue above, it’s a great machine. Almost silent like all of the other appliances we just installed. Super happy.
Bob
wow...
Congratulations that's some handsome machine you got there. And I do believe that you will get years of very good service out of it.
Our washer and dryer will be approaching 14 years of hard daily service and we have not had any problems.
The washing machine does about 8 -10 cycles per week and if you work on 8 cycles that would equate to about 5 400 cycles in its lifetime.
We really can't fault the machine.
Hope you enjoy them for many years to come.
Regards
We are mostly using the Miele detergent which is dispensed by AutoDos. I have some Finish Ultimate but have not tried it yet.
Bob
Miele G7106 here
Hey Bob! Congrats on your new Miele dishwasher! They are great machines if a little quirky with the loading. But once you get the hang of it, you'll be amazed at how much you can get in there. Like you I added the second interim rinse to mine as well. I included some pictures from various loads I managed to get in there.
Chris
Very nice!
Congratulations on your new dishwasher! It's a beautiful machine! I hope it provides you with many years of trouble-free service.
I recently had a conversation with independent appliance repair guy with 30 years of experience and he proclaimed Miele makes the best dishwashers. He said they are the most reliable and last 20 years. Bosch is second best but they only last 10 years. Every other manufacturer has the same reliability and last only 5-7 years. I thought those were interesting statistics...
Walter, the China/Crystal cycle has lower wash and rinse temperatures compared to Normal, Pots, and Sani cycles. Also water spraing is gentler than other cycles.
New Miele dishwashers
Hi Bob, your new kitchen and dishwasher looked great. Miele makes very good dishwashers to be sure.
From our limited experience, they seem to be fairly reliable. If you do have problems with them, they can be quite expensive to fix but that’s true of a lot of things today.
Reply number six while it’s true that the longevity of dishwashers is about the shortest of any major Appliance it’s kind of ridiculous to say that the popular US brands only last 5 to 7 years only about 25% of dishwashers are replaced within seven years at most, so they obviously last a lot longer than that on average.
Most new dishwashers do a great job cleaning, and are quite quiet, I really like the capacity of the KitchenAid with true three rack design, and the similar May tags, they hold a lot more than most other dishwashers, especially the European designed ones which are smaller and width and depth and interior height .
John
Options…
In the Settings menu, there are several different options:
Enable / Disable AutoDos (Automatic Detergent Dispensing)
Change AutoDos dispense amount (less, standard or more detergent)
Rinse Agent dispense amount
Water Softener Hardness Setting
Enable second interim rinse
Enable “Extra Clean”. (Manual is vague about this and only that it increases time and temperature to improve cleaning performance)
I only enabled the Second Interim Rinse and entered my local water hardness setting.
Bob
Extra Clean
At least in the EU, that forces a pre-rinse on any cycle (even our Eco cycle), ups the wash temp and forces a "full" interim rinse.
Especially the Sensor cycles sometimes run a pulsed interim rinse which uses a bit less water, but does the 10s spray long pause algorithm.
In the service settings menu, the "interesting" options I have are:
- a further extra clean setting if the user accessible one isn't enough
- a further extra dry setting for the same reason
- a setting to prevent condensation on cabinets which extends the fan run time in general but especially after the AutoOpen phase
Quick Intense Wash
I was cooking this morning and had a full load of dishes. I tried out the Quick Intense Wash. Wow! It was quiet but you could definitely hear the spray intensity increase relative to the other cycles. Water usage was quite a bit more than the other routine cycles.
Results were amazing. Absolutely flawless even though it was a full load and I didn’t do much more than light scraping. Almost dry when I opened the door.
It was interesting because AutoOpen at the end of the cycle did not occur. I wonder if they figured that cycle would likely be used in a busy kitchen so that might be a nuisance. I’m sure there are people at Miele who consider that stuff.
This is a super machine.
Bob
Quick Intense with Auto Open Drying
Hi Bob,
When you run the Quick Intense wash, the door will remain closed for upwards of 30 mins or so after the cycle is complete. If you don't open the door yourself, it'll do so automatically. My dishwasher has front controls and at the end of the cycle, the display will alternate "Ready" and "Auto Open" until the door actually opens; then it just says "Ready" for about 10 mins and powers down.
Chris
