Miele little giant programming mode
They should I would think.
However, there could be a lock on it. The setting menu on these is usually locked with a code and that might keep you from accessing the programming menu.
Or Miele has completely locked that out for the Professional machines.
On these, you can have the machine on and start the procedure by closing the door I think.
So open the door with the machine on, hold start, close door, same procedure from there.
I think it’s been blocked - tried again but 5 press version doesn’t do anything. But 3 press service mode works fine. Good job the access code was left as 000 default
On the older machines
One had to disconnect the temperature sensor from the pcb before programming mode could be entered
Is supervisor level the same as programming mode for the little giants? I was expecting to see a heater rating option considering this model can be 13amp or 25
