vacfanatic
- Joined
- May 17, 2009
- Messages
- 380
As you all probably recall I got my new Miele W3033 in January, and absolutely love it. I've got over 300 hours on it so far
Anyway, about a month ago the LED drum light started to not work all the time. Not sure what to expect, I contacted Miele and explained that I'm very capable of such a simple repair, so they agreed to send me the LED drum light assembly. While it was in route, I took the top, front and sides off to do a bit of inspection to see what the problem was. Come to find out it was not the LED drum light assembly, rather the wiring harness connection had a finicky connector where they were pressed together. When the machine was on, a jiggle of the wiring harness connector was clearly the source of the intermittant short. I contacted Miele again and said that I found the problem was actually the wiring harness, and they shipped that out to me. I spent about 2 hours carefully disassembling the machine which was very easy, replaced the harness, new LED light, photographed the insides and put her back together. She's been running perfect ever since.
Here are some pics!
