Really loving the Miele washer.  Even though it’s on 120 VAC and uses a decent amount of water, it heats water quickly and maintains the temperatures nicely.
The manual suggests running a hot cycle periodically for cleaning. There is also a settings feature to remind you to run a hot cycle after a certain number of cycles. Other than that, there is no mention of doing routine cleaning. We are in San Diego and the water is very hard. Any suggestions about how often to periodically descale? I used to do it every other month on our LG. (I’d alternate bleach one month for cleaning then the next month use citric acid granules for cleaning.)
We are not using bleach in the Miele. Should I just run a Sanitary cycle with citric acid for cleaning / descale?
Bob
Bob
