White gas
When I used to go to Scout camp in the summer we used kerosene lanterns ad flashlights in the campsite at night. I remember walking past another troop's campsite one night and saw a lantern with a funny flame, like it was flaring much higher on one side than the other, unlike our kerosene lantern which had a flame that was of uniform height. Somebody said that they were burning white gas in the lantern which was not a good thing to do, because of the low flash point as discussed in this Wikipedia article:
"Generic lamp oil is available clear or in a choice of several colors and in scented and unscented forms. Although more expensive, lamp oil is highly refined and burns more cleanly and with less odor than kerosene. "Lamp oil" must not be liquid paraffin. "Water clear" K-1 kerosene is the next grade of preferred fuel for kerosene wick lamps. In some locations "
red kerosene" is sold, which is dyed red and is slightly less expensive than K-1 kerosene, as no
motor-fuel taxes are collected on it. Red kerosene is not recommended because the dye will gradually clog the lantern wick causing odor and reduced performance. "Klean-Heat" brand is another highly refined, cleaner-burning, nicer-smelling<sup class="noprint Inline-Template Template-Fact" style="white-space: nowrap;">[
<span title="This claim needs references to reliable sources. (March 2012)">citation needed</span>]</sup> kerosene substitute sold at many
hardware stores during winter. Citronella-scented lamp oil containing
lemongrass oil is sold for its
insect repellent properties. Citronella fuels should only be used outdoors. Liquid paraffin based "lamp oil" should only be used in round-wick lamps with a wick diameter of less than ⅝". Used in larger wicks, this fuel causes the wicks to clog.<sup class="noprint Inline-Template Template-Fact" style="white-space: nowrap;">[
<span title="This claim needs references to reliable sources. (December 2015)">citation needed</span>]</sup>
Flat wick kerosene wick lamps should only be operated with kerosene, lamp oil or Klean-Heat, but alternative fuels can be used in an emergency. Such fuels may produce additional smoke and odor and may not be usable indoors.
Tractor vaporizing oil is made from kerosene with some additive to make a
motor fuel for tractors. No. 1
diesel fuel (also called winter diesel) is about the same as
kerosene but with the additives to make it a
motor fuel.
Jet A jet-engine fuel is essentially kerosene with a few additives.
RP-1 (Rocket Propellant-1) is a highly refined form of kerosene outwardly similar to jet fuel, used as rocket fuel.
Round wick, center draft lamps, must only burn either Klean-Heat or low odor mineral spirits.
Any liquid with a low
flash point presents a high risk of fire or explosion if used in a kerosene wick lamp. Such liquids are dangerous and should not be used in a kerosene lamp or lantern. Examples include:
<ul>
<li>
Charcoal lighter fluid</li>
<li>
Gasoline (
petrol)</li>
<li>
Naphtha,
white gas or
Coleman fuel</li>
<li>Mineral spirits, paint thinner,
white spirit (Stoddard solvent)</li>
<li>Other hydrocarbon solvents such as
turpentine,
benzene,
xylene,
toluene,
acetone,
camphene, lacquer thinner</li>
<li>
Denatured alcohol"</li>
</ul>
