More Dangerous Then Dynamite - Washing Clothes With Gasoline
Sadly, I think most of the general public knew very little about the dangers of some of the products they were using as solvents back in the 50s and even much later.
Gasoline is absolutely not suitable as a solvent for cleaning - it's pretty nasty stuff and you should minimise your contact with it.
There wsre loads of highly dangerous practices, chemicals and appliances back in the "good old days".
Everything from solvent use to burning gas appliances that vented straight into rooms, smoking and all sorts of crazy cosmetics that would be banned now.
And that was before you looked at work place safety and environmental emissions from industry! Not to mention plenty of nuclear materials being fired into the atmosphere in the name of military testing by various countries.
Widespread use of coal in this part of the world too, little or no emissions standards for gasoline engines etc etc etc
We are much more aware and highly regulated about volatiles and solvents these days. The amount of times however, I hear people complaining about modern paints annoys me. Your woodwork might take a little longer to dry than in 1977, but it's a lot better than dealing with inhaling dangerous solvents!
Quick drying skirtings (baseboards) or cancer?! ...
I wonder will we see a peak and fall away in cancer rates as the generations exposed to that stuff dwindle and younger generations have had a much healthier environment.
Hi James,
I would disagree that people complaining about paint performance with the reduction of the VOC’s should just accept it. There still isn’t a replacement for Oil based enamel, that gives the same finish oil based paint did 10 years ago.
The oil based paint we’ve used in the last 5 years has gone all chalky within 3-4 years, but at least allows you to get a perfectly smooth finish with the full gloss. The Waterbased enamels dry that quickly, that unless you’re spraypainting, it is impossible to get a smooth finish without brush or roller marks. The closest finish we’ve been able to get to oil is with a scrub ale hospital grade water based enamel, but it costs $90 a Litre and still dries that fast that you have to be creative to keep it looking good when the light shines on the finished surface.
Taking the lead out of paint was good, but the product still needs to work when you reformulate it to be healthier.
Regards
Nathan
Benzene...
Actually gasoline contains a lot of benzene.
And yes, it's nasty stuff. And many chemicals with a "benzene ring" need to be treated with respect.
Flammable dry cleaning solvents were of course replaced with chlorinated hydrocarbons, like carbon tetrachloride, perc, etc. The problem there is that they tend to last forever, and when they get into the ground water they can contaminate wells for miles around. A lot of industries in the 30's to the 60's were not to careful about where they dumped used solvents. A lot of those places are now Superfund sites. Chlorinated hydrocarbons today are generally regarded as carcinogenic, as well as liver and kidney toxins. Not to mention that when they evaporate they can stay in the atmosphere for a long time and deplete the ozone layer.
They do make waterless cleaning of greasy grimy car parts a breeze, though.
Perc replacing hydrocarbons.
I know that a local dry cleaners in my area has gone back to using stoddard solvent because it is apparently better for the environment. Shores Cleaners in St Clair Shores I believe is the place. I was surprised when the man told me that, I was expecting perc.
