sudsmaster
Live and learn.
Have a Cuisinart Thermal Burr Grind 'n Brew machine that I really like.
No problems, really, with it. I even stopped using a Keurig machine in favor the the CTBGNB.
However I learned something today.
I had assumed that at the various brew strength settings, the machine simply bypassed the grounds and shunted hot water directly into the pot for the milder brew setting. Like on lesser coffee makers. To avoid this I would add less water to the machine for the same brew cup setting, thinking this would result in a stronger brew. And it did. But it turned out I didn't have to do that.
I had switched from "mild" to "medium" and noticed the machine was going through grounds quicker. Hmmm. Could it be the machine is smart enough to grind more beans at the stronger setting?
To test this, I timed the grinding at "mild" and "strong" settings. Sure enough on the 4 cup setting, the time for grinding on mild was 15 seconds. The time for strong, 20 seconds. That's a 33% increase. Not too shabby. Kudos to Cuisinart for getting that right.
Anyway, my discomfiture over having made an incorrect assumption about this machine, is more or less ameliorated by the fact that from now on I don't have to fuss around with different water levels but rather simply set the brew strength to what I want.
Of course for REALLY strong brew I could set it to "strong" and then add less water than indicated on the dial. Or set the dial to more cups than the water level.
Whatever.
Right now I'm happy with "medium".
Whatever.
