I think HP is a bad unit for power anyways for stuff like appliances. At least I always found technical literature in SI units, and that is what most people can relate stuff to.
200W is about what a good powerfull PC draws in low-med use cases.
1000W is what I vacuum my carpets at.
1500W is about the max power for a standard american 120V circut.
2000W is a iron, a kettle, a EU washer, a small burner on my induction hoob.
3000W is professional small vented dryer possibly, a strong steam generator iron, a big induction cook zone.
And 5000-6000 W is higher voltage standards in both EU and US, powering industrial washers and dryer, or in the US vented electric dryers.
Given 0.24hp equals about 180W.
That is considerable for a DW. We can compare that to some other pumps (WPs smaller 50-100W recirculation motor, and drain pumps with 25-50W, depending) and see that this will move more water for sure. We can put that into a frame of comparison.
Now, we have to consider one thing though: That is, if I'm right, for both racks at the same time. Let's ignore flow resitance to the top rack being bigger, and differen spry arm designs in top and bottom. That gives us 90W per rack.
I have picked up somewhere that BSH EcoSilenceDrives in DW can deliver up to 100W during certain cycles and with certain conditions. But can't cite a source of that right ow, had to do with the claim made by Neff here in Germany that their intensive cycle runs at 3bar.
That would be more per rack as we have an alternating rack system there.
WPs 55W are less per rack, and comparable to a Miele LittleGiant drain pump. I've seen these empty 20-30l in about 30sec (these are guestimates; was a high water level in a 65l drum machine and draing to about 30sec).
That is a flow rate of 10-15gal per minute, round about.
If the recirculation pump can move that, I'm already impressed.
In the Miele Semi-Professionals I mentioned earlier, we are talking 50gal. That shoudl be on par with the Maytag; don't know if the Miele operates both arms at once when that rate was measured.
Anyway, even though all these spread out widley from incadesent lightbulb-power equivalent over handmixer on slower speeds up to tower PC in idle, all these designs have been proofen to remove even heavy soil.
Rating these in power or size at all (I mean in power/size without comparison) dosen't help anyone. It's a nice fact to know, but dosen't say anything aout cleaning abilities.
I'll just bring up this tamed down quote: It's not only about size. Sure you need a certain minimum to be abled to do anything, but that isn't all that much. It is mostly about how you move it around and how everything else plays together.
Sometimes it dosen't work, sometimes it does. There is no step-by-step guide or flow chart to determine performance for sure.
To lighten up my verry energetic comment a bit, a bit on flowcharts:
https://imgs.xkcd.com/comics/flow_charts.png
