" flashing each display light for a second then skipping
Chris (gizmo)
have they any kids ?
This sounds like the rapid advance mode.
If someone has turned the dial to "end" (noon on dial) while she's (e.g.) on "prewash", the "wash" led flashes 3 times, then the rinse one, so the spin one ...... end
If you suddenly turn it back to the previous programme/temp it runs the corresponding step of the flashing light.
I use this trick to re-rinse *full drum* loads on permapress .... know that it is *verboten*, but when one's in a hurry ... no time to split into two loads, so....
Would be a different matter if a light is still flashing when the "end" one is steady (fault, but here let's touch wood)
Chris (gizmo)
