Forgot to mention, as per RCD, to add a tablespoon of MAYTAG Transmission oil to the brake assembly...quieter operation
Now it's time install the outer tub...once over again to make sure the opening is sanded smooth and clean
...I used WLG to grease the rubber area of the tub bearing seal...slides in easier
...completely flushed with the tub...place the outer tub into a position so you can attach the water level switch air dome
...then set the tub onto the transmission...next sand and wipe the outer tub bolt opening and install the 3 screw bolts/washer/plate, etc
...the SHORT one in the front and the LONGER 2 in the rear of the tub
VERY IMPORTANT: I used a hand socket wrench and a ratchet socket wrench...the hand socket wrench held the screw bolt in place (inside the tub) so the (rubber washer) DOES NOT MOVE as they're tightened...if so, it'll be damaged
...ratchet socket wrench tightens the washers/square plate, etc from the outside
...next I lightly added some ZOOM Spout Turbine Oil to tub bearing...which enhances the spinning cycles
